packed RBD Constraint to multiple animated OBJ
huge
Hi everyone,
search all the forums and can't find a way to glue constraint a voronoi fractured object to multiple animated objects .It works really fine on one object, but no way to make it stick on two or more objects
Some tests with hardconrel work, but a lot of wobbling, and also, i need the simplicity of the glue constraint(i want to use the strength factor)
I join my test file, if somebody can help me, it would be really appreciated!
thx by advance, and excuse my bad english, I'm french...
cheers
PackedConstToMultiAnmObj.hip
Edited by huge
wrong file extension
Glue doesn't work in this case because groups of glued objects are simulated together as a *single* rigid body with a compound collision shape, and impacts can then cause shapes to break off into separate objects. That means that If there are multiple animated static objects in a glued chunk, there's no sensible way to update the transforms of the other objects in the chunk - the solver just ends up picking the first one. Additionally, if there's only a single glued chunk, there's only one object in the sim and there won't be any impacts that cause the glue to break.
As the previous post mentioned, pin constraints are a better choice for the boundary region since they behave as a more traditional constraint where constrained objects are simulated separately.
  • Like 2
thanks everybody for your advices!
thx rich_lord and cwhite, tried the different constraint type and yes it works definitly well with the hard constraint
need to change the constraint_type attribute from all to position, but it s ok
rgblues , I digged your hip and that's exaclty what i'm trying to do thx a lot for sharing!!!
