Lucavfx Posted January 27, 2017 Share Posted January 27, 2017 Hi, I'd like to access the 'Hide When' parameter field in 'Edit Parameter Interface' via python. The idea is to access this field and store a string such as "{ showmoreinfo == 1 }". Is there a way to easily do this? I searched and found workarounds which involve calling the hide method i.e. hou.parm('/out/mantra1/vm_lightexport_scope21').hide(1) but this result in an inefficient system requiring hoops to achieve what I want. Any ideas? Thanks Luca Quote Link to comment Share on other sites More sharing options...
graham Posted January 27, 2017 Share Posted January 27, 2017 Disable/Hide When is handled through a parameters ParmTemplate conditionals dict. Consider this example of a button that is disabled/hidden when a toggle ('parm') is not checked: >>> pt=hou.parm('/obj/geo1/null1/parm2').parmTemplate() >>> pt <hou.ButtonParmTemplate name='parm2' label='Label'> >>> pt.conditionals() {parmCondType.DisableWhen: '{ parm == 0 }', parmCondType.HideWhen: '{ parm == 0 }'} >>> pt.setConditional(hou.parmCondType.DisableWhen, "{ parm == 1 }") >>> pt.setConditional(hou.parmCondType.HideWhen, "{ parm == 1 }") >>> pt.conditionals() {parmCondType.DisableWhen: '{ parm == 1 }', parmCondType.HideWhen: '{ parm == 1 }'} >>> n.replaceSpareParmTuple(pt.name(), pt) 1 Quote Link to comment Share on other sites More sharing options...
Lucavfx Posted January 27, 2017 Author Share Posted January 27, 2017 On 1/27/2017 at 4:09 PM, graham said: Disable/Hide When is handled through a parameters ParmTemplate conditionals dict. Consider this example of a button that is disabled/hidden when a toggle ('parm') is not checked: >>> pt=hou.parm('/obj/geo1/null1/parm2').parmTemplate() >>> pt <hou.ButtonParmTemplate name='parm2' label='Label'> >>> pt.conditionals() {parmCondType.DisableWhen: '{ parm == 0 }', parmCondType.HideWhen: '{ parm == 0 }'} >>> pt.setConditional(hou.parmCondType.DisableWhen, "{ parm == 1 }") >>> pt.setConditional(hou.parmCondType.HideWhen, "{ parm == 1 }") >>> pt.conditionals() {parmCondType.DisableWhen: '{ parm == 1 }', parmCondType.HideWhen: '{ parm == 1 }'} >>> n.replaceSpareParmTuple(pt.name(), pt) Expand Thanks, I'm getting closer now. The problem is that as in the case of image plane parameters they're specified as vm_channel_plane# however python param and parmTemplate calls expect parameter names to be explicit (i.e. vm_channel_plane23). Setting the conditionals dict to explicit parameters does not seem to apply in this case Quote Link to comment Share on other sites More sharing options...
graham Posted January 27, 2017 Share Posted January 27, 2017 In the case of something like that (and if say modifying more than one parameter, or the ones on digital assets) you'll want to use the hou.ParmTemplateGroup from the node like as follows: >>> hou.parm('/out/mantra1/vm_variable_plane1').description() 'VEX Variable' >>> ptg = hou.node('/out/mantra1').parmTemplateGroup() >>> ptg.find("vm_variable_plane#") <hou.StringParmTemplate name='vm_variable_plane#' label='VEX Variable' length=1 naming_sch >>> pt = ptg.find("vm_variable_plane#") >>> pt.setLabel("This is a test") >>> ptg.replace(pt.name(), pt) >>> hou.node('/out/mantra1').setParmTemplateGroup(ptg) >>> hou.parm('/out/mantra1/vm_variable_plane1').description() 'This is a test' 1 Quote Link to comment Share on other sites More sharing options...
Lucavfx Posted February 6, 2017 Author Share Posted February 6, 2017 On 1/27/2017 at 5:51 PM, graham said: In the case of something like that (and if say modifying more than one parameter, or the ones on digital assets) you'll want to use the hou.ParmTemplateGroup from the node like as follows: >>> hou.parm('/out/mantra1/vm_variable_plane1').description() 'VEX Variable' >>> ptg = hou.node('/out/mantra1').parmTemplateGroup() >>> ptg.find("vm_variable_plane#") <hou.StringParmTemplate name='vm_variable_plane#' label='VEX Variable' length=1 naming_sch >>> pt = ptg.find("vm_variable_plane#") >>> pt.setLabel("This is a test") >>> ptg.replace(pt.name(), pt) >>> hou.node('/out/mantra1').setParmTemplateGroup(ptg) >>> hou.parm('/out/mantra1/vm_variable_plane1').description() 'This is a test' Expand Thanks Graham that helped quite a bit Quote Link to comment Share on other sites More sharing options...
