Slimesunday Posted January 30, 2017 Share Posted January 30, 2017 Im pretty new to houdini and im trying to create a vector volume inside a torus. It sounds so simple but im struggling to figure out how to do it. The volume sop is super easy to use and allows you to choose a vector volume. Unfortunately, the volume is only defined within a cube. How can I achieve the same set up inside a torus? Quote Link to comment Share on other sites More sharing options...
Atom Posted January 30, 2017 Share Posted January 30, 2017 You can follow up your torus node with an isoOffset. Remember to increase the Uniform Sampling, the default of 10 is rarely enough. Quote Link to comment Share on other sites More sharing options...
Slimesunday Posted January 30, 2017 Author Share Posted January 30, 2017 @AtomThanks Atom. Can this hold a velocity attribute? Im trying to create this effect inside a torus Quote Link to comment Share on other sites More sharing options...
