[SOLVED] Python relative reference path inside HDA
LaszloFX
Hey Guys!
I have a pretty newbie question about some Python and HDA interaction.
So in a nutshell I'm trying to create an HDA with implemented Python script which does the following:
1. I have an Original Geo, which is object merged in my HDA.
2. I select some primitives on my original geo (or on the HDA).
3. After I selected my primitives, with a press of a button on my HDA, the selected primitives will be added to a group's pattern parameter inside my HDA.
4. And of course it would be great if this could work with a relative reference, so if I copy my HDA multiple times it'll update the groups within the correct HDA.
I have this code so far:
import toolutils
viewer = toolutils.sceneViewer()
geo = viewer.selectGeometry()
s = geo.mergedSelectionString()
# How can I make THIS PATH relative reference?
n = hou.parm('/obj/Colorzied_Geo_Asset_1/Colorized_GEO/group1/pattern')
n.set(s)
I put together a pretty simple example file and the hda, which will hopefully help you guys understand what I'm trying to achieve.
In case my explanation is a little confusing. :)
selectedPrims_python_problem_v001.hip
colorzied_geo_asset.hda
Any help or nudge in the right direction would be greatly appreciated!
Thanks in advance!
Best,
Laszlo
Edited by LaszloFX
Hey Guys!
In the mean time, I found the solution.
I realized that if I put my code inside a function, I can recall that function with the HDA Callback Script.
I know this must be pretty basic information to most of you, but for me it opened up many mental doors and windows. :D
And just in case anyone is interested, here is the code that is inside my HDA's Type Properties Scripts Tab:
import toolutils
def sel():
    n = hou.parm('./grid/group1/pattern')
    n.set(s)
And this code goes into my Callback Script under my Button parameter to call back my function defined above:
kwargs['node'].hdaModule().sel()
And here are my example files as well:
selectedPrims_python_problem_v002_SOLVED.hipFetching info...
colorzied_geo_asset.hdaFetching info...
Thanks anyway for taking a look at my problem, and I hope some of you may find it useful as well! :)
Best,
Laszlo
  • Like 3
