Hans Peter Posted February 5, 2017 Share Posted February 5, 2017 Hi, probably a simple one but I'm having problems deleting points based on a point attribute called "wet". So its a wet map. The delete sop isn't willing to delete anything here. Any hint? Thanks Quote Link to comment Share on other sites More sharing options...
Sepu Posted February 5, 2017 Share Posted February 5, 2017 I believe it should be @wet since you have it as an attribute, unless you also made a local variable. Also should be like @wet==0 Quote Link to comment Share on other sites More sharing options...
Hans Peter Posted February 5, 2017 Author Share Posted February 5, 2017 Arr, yes, it was a == Quote Link to comment Share on other sites More sharing options...
