Maurits Posted February 8, 2017 Share Posted February 8, 2017 Hallo all. If been trying to get the HDK to work on my pc, but what ever I try it fails to compile. I tried both visual studio 2012 and 2015, and using the command line hcustom, I have 2 version of Houdini on my PC Houdini 15.0.465,Houdini FX 16.0.504.8 on a windows 10 pc. Searching for possible solutions didn't yield any results either, so I was hoping someone here could help me out. Thanks in advance . Included are the error logs for both VS. vs2012.txt vs2015.txt vc2012.log vs2-15.log Quote Link to comment Share on other sites More sharing options...
MrScienceOfficer Posted February 8, 2017 Share Posted February 8, 2017 You need to use 2015. Definitely use the latest production build, if possible. Try that combination and see if it helps. Quote Link to comment Share on other sites More sharing options...
Maurits Posted February 9, 2017 Author Share Posted February 9, 2017 Unfortanite i't did not help I tried 2015 with the latest stable build of Houdini 16 but still it failed. HDK_test.log Quote Link to comment Share on other sites More sharing options...
Mandrake0 Posted February 9, 2017 Share Posted February 9, 2017 Get in contact with SESI H16 is not jet public. Quote Link to comment Share on other sites More sharing options...
edward Posted February 10, 2017 Share Posted February 10, 2017 cl : Command line warning D9025: overriding '/TC' with '/TP' cl : Command line warning D9025: overriding '/MDd' with '/MD' These warnings say to me your environment variables must be severely messed up. First of all SAVE a copy of all your environment variable values before doing anything else. Now, offhand: - Remove anything Visual Studio related from your PATH environment. This was only necessary on 32-bit Windows. You *must* be running 64-bit Windows. - Remove anything that looks compiler related before running hcustom other than MSVCDir. Make sure MSVCDir is pointing to VS 2015's VC directory. Remove these if you see them: LIB, INCLUDE, CFLAGS, CXXFLAGS, or anything else similar. Now try again using the Houdini Command Line Tools from the Start Menu and hcustom. Quote Link to comment Share on other sites More sharing options...
Maurits Posted February 10, 2017 Author Share Posted February 10, 2017 I Got hcutom to compile a sample node, and it works in 16 event though hcustom crashes afterwards, but that could be the same as another post about it crashing on windows 10. Unfortunately Visual studio still fails to compile for me at this time. At least i can start with experimenting and learning to make node's / vex functions Unfortanite i't did not help I tried 2015 with the latest stable build of Houdini 16 but still it failed. Quote Link to comment Share on other sites More sharing options...
edward Posted February 14, 2017 Share Posted February 14, 2017 So what fixed it? Quote Link to comment Share on other sites More sharing options...
Maurits Posted February 14, 2017 Author Share Posted February 14, 2017 Not sure, I did what you advised and removed or changed some of the environment variables.But I got something to work with Getting VS to work is just a luxury for me now. Thanks for the help! Quote Link to comment Share on other sites More sharing options...
