Bernard Posted June 15, 2005 Share Posted June 15, 2005 Hello, I'm doing the rocket tutorial of the Houdini help files. When I sculpt the moon surface , I can only PULL the surface. The tutorial says LMB pull and MMB push. For me the MMB gives the same effect as LMB. How can I push my surface IN? Many thanks Quote Link to comment Share on other sites More sharing options...
DaJuice Posted June 15, 2005 Share Posted June 15, 2005 Hmm, try ctrl-right clicking when you're sculpting, and make sure your MMB funtion isn't set the same action as the LMB. Quote Link to comment Share on other sites More sharing options...
edward Posted June 16, 2005 Share Posted June 16, 2005 Double-check that when you middle-click on the geometry, the Sculpt parameters show that it switches to MMB Displacement. Then the BD parameter underneath should be negative. Quote Link to comment Share on other sites More sharing options...
Bernard Posted June 16, 2005 Author Share Posted June 16, 2005 Hello, I've set the BD parameter to -1 and now it works perfect when I click the MMB. Many thanks Quote Link to comment Share on other sites More sharing options...
