Hokmah Posted February 27, 2017 Share Posted February 27, 2017 (edited) I have a little problem which maybe not so complicated but what is the easiest way to change particles from attchment in smoke? I can't make from it ISO so? Is there any other easy and fast way for this? I would like to achieve something like a smoke/mist.. test_smoke.hip Edited February 28, 2017 by Hokmah Quote Link to comment Share on other sites More sharing options...
ThomasPara Posted February 27, 2017 Share Posted February 27, 2017 you can turn points into a volume with the "vdb from particles" node, and then just set it to a fog volume. Quote Link to comment Share on other sites More sharing options...
Hokmah Posted February 28, 2017 Author Share Posted February 28, 2017 8 hours ago, ThomasPara said: you can turn points into a volume with the "vdb from particles" node, and then just set it to a fog volume. Sure but then it looks like made from lots of small spheres.. Is it posibble do achieve results more like a cloud? Quote Link to comment Share on other sites More sharing options...
Hokmah Posted February 28, 2017 Author Share Posted February 28, 2017 ok, VOP solved my problem Thank you. Quote Link to comment Share on other sites More sharing options...
danell Posted March 3, 2017 Share Posted March 3, 2017 On 2/28/2017 at 8:53 AM, Hokmah said: ok, VOP solved my problem Thank you. Care you share the VOP? Trying something simular Thanks! Quote Link to comment Share on other sites More sharing options...
