chrisdunham95 Posted October 11, 2017 Share Posted October 11, 2017 (edited) Lil update for anyone interested - I got sprites to work by turning on two sided which made them visible and fixed the issues (within the UE4 Shader) Edited October 11, 2017 by chrisdunham95 Quote Link to comment Share on other sites More sharing options...
LucidMovement Posted October 11, 2017 Share Posted October 11, 2017 (edited) 9 hours ago, chrisdunham95 said: Lil update for anyone interested - I got sprites to work by turning on two sided which made them visible and fixed the issues (within the UE4 Shader) I often have to flip normals when exporting from Houdini. Could probably fix that prior to export if double sided is undesirable. One thing that helped me find this prior to export is in the display options, under optimize, flag the remove backfaces option. But it also could just be an issue in the export rop. Good find! The fluids issue is strange. I'll run through the fluids tomorrow and see if I can figure out the magic settings. I realized last night after I posted that what I thought of as my "fluid" is actually not a fluid export but a soft body export. The simulation is fluid, but I use that to displace the original mesh since I was just doing some melting stuff. So it is possible I never did figure out the fluid end. I'll dig around though and see if I can find anything useful. Oh, random thought, you could double check the import settings on the texture to see if it is set to Vector Displacement instead of a standard compressed file. Edited October 11, 2017 by LucidMovement Quote Link to comment Share on other sites More sharing options...
chrisdunham95 Posted October 12, 2017 Share Posted October 12, 2017 (edited) 18 hours ago, LucidMovement said: I often have to flip normals when exporting from Houdini. Could probably fix that prior to export if double sided is undesirable. One thing that helped me find this prior to export is in the display options, under optimize, flag the remove backfaces option. But it also could just be an issue in the export rop. Good find! The fluids issue is strange. I'll run through the fluids tomorrow and see if I can figure out the magic settings. I realized last night after I posted that what I thought of as my "fluid" is actually not a fluid export but a soft body export. The simulation is fluid, but I use that to displace the original mesh since I was just doing some melting stuff. So it is possible I never did figure out the fluid end. I'll dig around though and see if I can find anything useful. Oh, random thought, you could double check the import settings on the texture to see if it is set to Vector Displacement instead of a standard compressed file. Ahhh yes good thought! Ahhhhh strange that a fluid works through the soft body export but I will give that a try myself and see the results, yeah again nice thought I will keep it in mind but most of the time textures seem to recognise correctly, Thanks again Neil - Little update; tried the soft body method with a small moving fluid but couldn't get the translation to work, sooo went back to the fluid method but still getting the exact same look (almost asif the position map is baked with higher polycount/vertex count than the fbx I import and so cannot move all verts correctly but the movement is roughly correct) - Another thought, Has anyone found it necessary to manually set the bounding box parameters (min/max) within the UE4 shader? thought it maybe fix some issues but perhaps a hopeful but simple solution Please see the issues with my fluids inside UE4 in the video below 2017-10-11_Capture_Fluid_Mesh_Issues.flv Edited October 12, 2017 by chrisdunham95 Adding attatchments Quote Link to comment Share on other sites More sharing options...
chrisdunham95 Posted October 12, 2017 Share Posted October 12, 2017 Found a solution to my above issue - my frame range in the shader was off by 1 due to a bit of personal error! So fluids working - and for anyone having RBD issues make sure fully precisions uv's are turned on and the filter inside the mesh I believe should be set to nearest which should help Quote Link to comment Share on other sites More sharing options...
LucidMovement Posted October 12, 2017 Share Posted October 12, 2017 Oh, wow. Useful info, didn't know it would fail in that way with the frame being off. Good to know! The bounding box min/max I've always had to set. The UE4 shaders they give you to copy I think are just generics. Once you have one in your project you can just make material instances and set the settings according to that particular export. 1 Quote Link to comment Share on other sites More sharing options...
Gerbrand Posted October 20, 2017 Share Posted October 20, 2017 (edited) On 10/11/2017 at 11:46 AM, chrisdunham95 said: Thanks for the tips Neil! I also have the soft method working - still having odd rotation issues with RBD - Sprites work perfectly except they are invisible?? regardless of what I do to the shade but you can see their moving correctly when highlighted so I'm sure that maybe a small fix - Fluids I'm still getting the same results regardless of changing resolutions (texture/sim/etc) see the video below - any solutions for any of this would be super handy, Thanks Guys, 2017-10-11-1044-27.flv I get the same results every now and again.. then I restart. Sometimes this fixes it, sometimes not so much. Right now I only get black color maps. Something broke between houdini 16.705, and h16.736 it seems. These effects are awesome when they work. I've got them in my game at the moment The button is a soft vertex anim, and the explosions are fluid. remember to keep color as point data if you want to export colormaps Good luck man! Edited October 20, 2017 by Gerbrand 2 Quote Link to comment Share on other sites More sharing options...
chrisdunham95 Posted October 20, 2017 Share Posted October 20, 2017 42 minutes ago, Gerbrand said: I get the same results every now and again.. then I restart. Sometimes this fixes it, sometimes not so much. Right now I only get black color maps. Something broke between houdini 16.705, and h16.736 it seems. These effects are awesome when they work. I've got them in my game at the moment The button is a soft vertex anim, and the explosions are fluid. remember to keep color as point data if you want to export colormaps Good luck man! Very nice man :), don't suppose anyone has got sub-uvs/flipbooks in unreal to work with custom color passes from Houdini - Use the color pass to pick which sub uv texture to use for example? - UE4 more than Houdini related question but any idfeas would be great, had some success with messing around but not to the extent I want, Thanks guys Chris - PS ; (Vertex Animation tools Beta - all work fine for me now for all export types ) Quote Link to comment Share on other sites More sharing options...
Gerbrand Posted October 20, 2017 Share Posted October 20, 2017 anyone know why this happens on fluids? I have polyreduce set to number, and i force it to 10000 polys, so i don't think its a polycount thing. I even tried a version where I used 1010 as the target on the export. No dice. Quote Link to comment Share on other sites More sharing options...
chrisdunham95 Posted October 20, 2017 Share Posted October 20, 2017 19 minutes ago, Gerbrand said: anyone know why this happens on fluids? I have polyreduce set to number, and i force it to 10000 polys, so i don't think its a polycount thing. I even tried a version where I used 1010 as the target on the export. No dice. Few things to check - inside your UE4 shader/material make sure your frame range is set correctly (1-100 in Houdini is 99 frames for unreal) - Inside your mesh fbx in UE4 check full precision UV's (can sometimes make a difference) - and can also check your normal before the export over? - Another lil thing is going into your UE4 position maps/textures and changing the filter to nearest (more precision) Let me know if any of these fixes your issue Quote Link to comment Share on other sites More sharing options...
Gerbrand Posted October 20, 2017 Share Posted October 20, 2017 there must be something weird with my setup.. I took a break, came back, saw your post, and opened the project. Guess what.. It's fixed I only stepped away, and came back, so either it was fixed by a magical unicorn, or my 2 year old is better at this shit than me. Weird G 1 Quote Link to comment Share on other sites More sharing options...
Guest Nghia Nguyen Posted March 22, 2018 Share Posted March 22, 2018 Hi, I'm newbie in unreal. I just want to ask, How can I play the vertex animation only once time, not loop anymore? thanks Quote Link to comment Share on other sites More sharing options...
shalivan Posted March 22, 2018 Share Posted March 22, 2018 (edited) You are driving your anim by moving uv across time. If you dive into unreal shader and repleace 'Time' node by variable, values: 0-1 will scroll throu anim. Edited March 22, 2018 by shalivan Quote Link to comment Share on other sites More sharing options...
Guest Nghia Nguyen Posted March 23, 2018 Share Posted March 23, 2018 @shalivan Could you tell me the node to scroll the time variable ? I try several time yesterday but it not work. Then I want to control this animation by a button on keyboard Could you help me? Quote Link to comment Share on other sites More sharing options...
shalivan Posted March 23, 2018 Share Posted March 23, 2018 You can use variable Or parrameter collection. More info here: 1 Quote Link to comment Share on other sites More sharing options...
Guest Nghia Nguyen Posted March 23, 2018 Share Posted March 23, 2018 @shalivan Thank you so much. Awesome. I will try it today. Hope it work. Have a nice day Thank you Quote Link to comment Share on other sites More sharing options...
Guest Nghia Nguyen Posted March 23, 2018 Share Posted March 23, 2018 @shalivan: Hello again Sorry but in blue print, how can I set a variable run from 0 to 1 just one time ? Now I just can control the specific number when I press a keyboard. And it not an animation . It's just one random freeze state of the animation Quote Link to comment Share on other sites More sharing options...
Guest Nghia Nguyen Posted March 23, 2018 Share Posted March 23, 2018 @shalivan May be I will try this way, set the time counter. Still need your help if you have the right way. Thanks. Quote Link to comment Share on other sites More sharing options...
shalivan Posted March 23, 2018 Share Posted March 23, 2018 You can make a timeline, and put time curve inside: You can also try to use: material parammeter collection + sequencer. Quote Link to comment Share on other sites More sharing options...
Saya Posted August 30, 2021 Share Posted August 30, 2021 Hi all, I've been trying to export this animation to UE4. But I'm experiencing some issues for the export and can seem to find a good guide on the setup. I've got 2 setups for the same base geo. The first one uses prims that are scaled, are somewhat translated and has uv's. But the VAT does not let me export it as an soft animation. I read this geo as a soft animation with same topo. The second one are lines that are carved and move around. But VAT does also not allow me to export this. I read this geo as changing topo, so its a an fluid? Hopefully someone can help me out. Thanks in advance geo_transform.hip #1 #2 Quote Link to comment Share on other sites More sharing options...
