Keep orientation when sweeping on a spiral
Im trying to sweep a geometry around a spiral I created in VEX but Im having a problem as the cross section slowly rotates.
I tried to set @up and @N attributes and use Transform Using Attributes but it generates other problems.
As you can see the rectangle that Im sweeping rotates over time (I think it does a 360 rotation over the whole path)
mj_spiral_test.hip
