yibo zhang Posted March 13, 2017 Share Posted March 13, 2017 Hi all I maked a very common break, only a box and some points to fracture and packed. Know i want to find the rotatioin angle through 'w' attribute. No matter what way can be... Thanks! Quote Link to comment Share on other sites More sharing options...
Atom Posted March 13, 2017 Share Posted March 13, 2017 Isn't v@w rotational velocity? If so I don't think you can determine the angle. I mean the angle is the current angle plus whatever v@w is currently set to. Just like you can't find a location just using v@v. It will always be based upon the current location modified by the attribute. Quote Link to comment Share on other sites More sharing options...
yibo zhang Posted March 14, 2017 Author Share Posted March 14, 2017 7 hours ago, Atom said: Isn't v@w rotational velocity? If so I don't think you can determine the angle. I mean the angle is the current angle plus whatever v@w is currently set to. Just like you can't find a location just using v@v. It will always be based upon the current location modified by the attribute. Thanks for your answer. I want to put each piece into a sparate Geo.Intend to turn the movement of the fragment into a key frame of the Geo layer set.Function like Thinking Particles of export. Quote Link to comment Share on other sites More sharing options...
