Is there a way to debug memory consumption?
Hi Guys,
I have a simulation with roughly 50K RBDs and 27K constraints.
All the rbds are packed (using mid button H16 says that they occupy 40mb instanced) but still, when I perform the sim, it takes up all my ram 63.8Gb.
Is there a way I can debug this? How do I know what is taking memory?
Thank you!
Lazza
I guess you would use the Performance Monitor to try to determine where memory consumption is the greatest.
Really? 50,000 RBD objects. Whew that is a lot.
If your motherboard supports up to 128GB maybe you could upgrade your memory?
Around 10GB of memory usage in the Bullet solver is in the ballpark of what I'd expect for a sim of that size. Is there any indication of what nodes account for the other ~50GB (perhaps SOPs for the simulation's input geometry)?
actually, this result is just after 30/40 frames. Most of the rbds are still inactive...
You mean outside the dop? I mean, where the dops "points" for the RBD packed geos?
Edited by lazza79
