issue with piston animation with chop and constraints
FR3D
I am trying to animate an engine using chops and constraints.
I manage to get something quiet close but it isn't accurate(cheat)
My main issue is that i cannot find how to use a "look at" in conjunction with some restriction to force the tip of the arm to slide along the Y axis.
I tried many other solution as well as trigonometry(which i am not very good at) which i gave up on.
i also tried with bones but again my knowledge is close to none in houdini and i wasn't able to restrict bones
I wish to achieve the real thing with your help
Thank you
piston.hip
Edited by FR3D
Ok, i managed to get the trigonometry formula.
Now i have two method.
one is Hscript which works perfectly(u can check the measure sop) and the other one is VEX.
For some reason the Vex(into a point wrangle)works but is speed up.I am pretty sure it is the same script.
Does the wrangle node manage "@frame" differently than "$FF" in hscript?
piston trigonometry.hip
Edited by FR3D
nope no difference between $FF and @Frame (when bound to float attrib).
the reason your file isnt working correctly is because in VEX for cos/sin you have to provide the value in Radians. Apparently hscript is fine with Degrees.
here you go: @P.y =  @r*cos(radians(@a))+sqrt(pow(@l,2)-pow(@r*sin(radians(@a)),2));
