markerline Posted June 28, 2005 Share Posted June 28, 2005 Dear users: In the viewport as well as the SOP pane I find that I cannot see the selection marquee when I am click-dragging around points or SOPs. I imagine that this is because the selection marquee is the same exact color as the background in each pane. Is there a way to change the interface colors to make the selection marquee appear? Thanks in advance for any help. -penciline Quote Link to comment Share on other sites More sharing options...
Jason Posted June 28, 2005 Share Posted June 28, 2005 Hey there, There is an environment variable you could try setting: setenv HOUDINI_OGL_MARQUEE_FIX 1 This env var has been around for a million years so I don't know if its still valid. Hope it helps, Jason PS. If you're on windows, you could set it in ControlPanel->System->Environment->Advanced. PPS. If you want to see all the available Houdini environment variables, type this in a shell which has the Houdini environment set: hconfig -a Quote Link to comment Share on other sites More sharing options...
markerline Posted June 28, 2005 Author Share Posted June 28, 2005 Hey there,There is an environment variable you could try setting: setenv HOUDINI_OGL_MARQUEE_FIX 1 This env var has been around for a million years so I don't know if its still valid. Hope it helps, Jason PS. If you're on windows, you could set it in ControlPanel->System->Environment->Advanced. PPS. If you want to see all the available Houdini environment variables, type this in a shell which has the Houdini environment set: hconfig -a 19091[/snapback] Thanks. I tried it but it apparently doesn't work on my machine. However, I forgot to mention another quirk that I discovered: When I try to drag and drop SOPs, the SOP doesn't follow the mouse. It only ends up where I drop it. This is sort of a pain when I try to organize my SOPs snice I can't tell where anything is going to end up in my pane. Thanks in advance for any help. Quote Link to comment Share on other sites More sharing options...
edward Posted June 28, 2005 Share Posted June 28, 2005 Try setting HOUDINI_OGL_DBL_BUFFER_FIX to 1. Quote Link to comment Share on other sites More sharing options...
markerline Posted June 28, 2005 Author Share Posted June 28, 2005 Try setting HOUDINI_OGL_DBL_BUFFER_FIX to 1. 19093[/snapback] That was it! Thank you very much! Quote Link to comment Share on other sites More sharing options...
Jason Posted June 28, 2005 Share Posted June 28, 2005 That was it! Thank you very much! 19094[/snapback] No problem; btw, what video card / drivers are you using? This kind of thing is good to document on the Wiki. Quote Link to comment Share on other sites More sharing options...
markerline Posted June 28, 2005 Author Share Posted June 28, 2005 No problem; btw, what video card / drivers are you using?This kind of thing is good to document on the Wiki. 19095[/snapback] Using ATI FireGL T2 graphics card, 128MB Video RAM, 1280x1024, driver version ati2dvag.dll (6.14.0010.6467 (7 Sept 2004). Hope this info helps you. Quote Link to comment Share on other sites More sharing options...
