houdini takes forever to load
hello..
i was wondering if anyone is having the same problem as me...whenver i load a geometry...it takes too much time to load but it evntually loads .However,when i load certain objects such a simple biped character...it just does not load it..ON the bottom bar it says (evaluating python,etc etc...it takes more than 3 minutes and obviously after i wont bother with it again and i'll try closing but it just wont close.
btw im using the houdini apprentice non-commercial and its been 2-3 days since i downloaded it
Check SideFX hardware requirements to make sure your system meets the minimum requirements. Also make sure you have some free space on your hard drive. I typically try to keep at least 30-40GB free on my main drive.
Also, the official H16.0504.20 release had some viewport problems that have been fixed in the daily builds. I too experienced slow load time when I initially upgraded from H15.5 to H16 but have since installed a daily build and things are better.
Yes, daily builds are available for Apprentice users.
