Mixamo Abc import via c4d
I got an animation from mixamo.com in fbx... used c4d to export out an abc - this file opens fine back in c4d. But doesn't show any geometry inside houdini.
 Is there something I am missing/  doing something wrong? If this won't work does anyone know a convenient way to get mixamo animation inside houdini?
Thanks
d.
You can import directly the fbx downloaded from mixamo in houdini. Then make a geo node with object merge, select the fbx obj group path and rescale with a transform sop.
You can use timeshift and attribute interpolate if you want to stick scattered points
