Apply VDB from polygon and VDB Reshapes
I am confused on what exactly is the problem here? From looking at your file, the vdb reshape is working correctly and it is grouping the points inside the pig. I assume that is what you want because that is what the grains masterclass is doing with this (which you are creating this from).
Using Houdini 16.0.542
