Obj
YOu can't export sequences of BGEOs in Houdini Apprentice  (coz it's free!) - but you can a bought version using a Geometry ROP.
http://odforce.net/wiki/index.php/HoudiniApprentice
19152[/snapback]
Why did they exclude this Geometry ROP. What can somebody do with this obj files alone. That there is a watermark in the render ,I understand but why not exporting obj possiblity?
Many thanks!
Many thanks!
19153[/snapback]
It would make it easy to use Houdini Apprentice as a full animation package then, merely exporting geometry to a licensed version for rendering without watermarks. For medium size facilities, you'd need only one licensed version then, no? Apprentice could be used just as a front-end for free in this case.
We should be so lucky that it even supports .obj for still models, IMHO. Since .obj is not really lossy like a watermarked JPEG is you make a parralel with rendering. For a truly secure route, it should only read/write encrypted/watermarked .bgeo files (which would be able to support sequences but switch any Houdini session down to Apprentice mode), but they've allow poeple to interchange freely between packages using .obj.
I try not to look a gift horse in the mouth in this case. :)
19154[/snapback]
Hello, thanks Jason, now I understand.
Wouldn't it be possible to Save each geometry (bgeo) per frame: frame1, RMB save geometry, frame2, RMB save geometry, and so on...
Thanks,
Bernard
Thanks,
Bernard
19155[/snapback]
Yeah, which is why its not so secure. And you certainly can't build a pipeline around that - well, not an efficient one. ;)
19157[/snapback]
Yes I see. For 5 or 10 frames it's do'able, but not for a 100 or more...
Many thanks for the fast reply!
