Solver Questions Please
If I understand you correctly, do you mean you want to move these objects on the terrain (so they avoid hills, ...)? If so then you should try crowd solver... If not, then what's it you want to do, i.e. do you want to place objects on the ground only, do you want to move them,etc. ?
Yes Yes avoiding terrain red ball
sorry, i' m very immature in English ㅠㅠ
:D
Okay :) have you tried using the crowd solver? I did test it quickly and there are ways to make objects "walk" on the ground and avoid some areas, go toward certain areas, etc... just look at some tutorials and you will get the general idea... Good luck :)
