Guided ocean not guiding properly
Hans Peter
Hey there,
some problems with the guided ocean thingy here. So it actually isn't following the ocean surface after a while. Getting pretty flat. Any idea why thats happenning?
Starts with a pretty good match but then leafes the shape. Nothing special done with the setup, its pretty basic. tank around 40*60m large.
  • 2 weeks later...
Maybe your source node has time limited by expression. Check your source node. If that is not the case share your file here. I can have a look.
Ranadeep
FX TD @dNeg
