Foreach Block vs Subnet giving different results
This has been driving me insane for the last half an hour so I thought I'd see if anyone here has any insights.
I've made two near identical setups. One in a foreach subnet (working correctly) and on in a foreach block (not working correctly).
I've attached a simplified setup to demonstrate the problem.
I suspect it has something to do with the "merge each iteration" option. Which seems to work slightly differently on the blocks. It's like it's not feeding the results back into the next iteration correctly.
Any ideas?
There's no real reason that I can't use a subnet, I'm just intrigued as to why the results are so different. I'm sure it's just me doing something wrong.
FOREACH_Loop_vs_Subnet_01.hiplc
Edited by PixelNinja
Ah, that stamp was a holdover from copying stuff around. It's meant to be a detail() function.
The "fetch feedback" also doesn't work for me. I still get basically the same result.
What result were you getting?
That's weird. "Reset cached pass" did nothing.
I changed the expression back to:
`rint(rand(detail("../foreach_begin1_metadata1/","iteration",0))*npoints(0))`
and set the foreach to "fetch feedback".
I'm on version 16.0.557. Which version are you on?
Ah I'm an idiot.
It was the "fetch feedback"!
For some reason I thought you meant the "Gather Method" on the end block, not the "Method" on the begin block. Sorry, I must have skimmed your response too quickly.
Thanks for that!
