angad.singh06 Posted May 7, 2017 Share Posted May 7, 2017 I am not able to emit fluid from mesh that I imported as ABC from Houdini. Getting this error. I also get the same error when I apply a MEL script that applies shaders randomly. // Error: file: /Applications/Autodesk/maya2016/Maya.app/Contents/scripts/others/dynExecFluidEmitterCommands.mel line 47: Object 'file1_106' not found. Attaching the abc file as well skelly2.abc Quote Link to comment Share on other sites More sharing options...
lavitz01 Posted May 8, 2017 Share Posted May 8, 2017 If i remember correctly when you send simulation data from Houdini to Maya it converts everything to geo. if you want to make changes you need to make them in houdini and re-send the sim data over. Also you could check the attribute editor to see what values you have control with and maybe check with deformations. that could help you achieve what needed if its nothing major. Quote Link to comment Share on other sites More sharing options...
