onkardahare Posted May 21, 2017 Share Posted May 21, 2017 (edited) I created debris particles after fracturing the object. Now I am not able to collide those instance debris with each other and with static ground. please help me on this. Edited May 21, 2017 by onkardahare Quote Link to comment Share on other sites More sharing options...
Atom Posted May 21, 2017 Share Posted May 21, 2017 Can you post your work in progress file? Quote Link to comment Share on other sites More sharing options...
onkardahare Posted May 22, 2017 Author Share Posted May 22, 2017 the file worke on houdini 15 noncommercial Debris.hipnc Quote Link to comment Share on other sites More sharing options...
Atom Posted May 22, 2017 Share Posted May 22, 2017 Your hip file is missing the external rock debris object that it references. Anytime you just copy geometry to points after a simulation there will be no enforced collision. You must send the pieces into the simulation so the simulator can collide correctly. Quote Link to comment Share on other sites More sharing options...
onkardahare Posted May 22, 2017 Author Share Posted May 22, 2017 how will i send the pieces into the simulation so the simulator can collide correctly? i am not getting which dop should i use. Quote Link to comment Share on other sites More sharing options...
Atom Posted May 22, 2017 Share Posted May 22, 2017 There are some examples on this forum. Basically search on packed primitives. Here is a link to one such setup. https://www.sidefx.com/forum/topic/49477/#post-223555 You can also click on the link in my signature and find a few more. 1 Quote Link to comment Share on other sites More sharing options...
onkardahare Posted May 23, 2017 Author Share Posted May 23, 2017 thankyou for help Quote Link to comment Share on other sites More sharing options...
