Font subdivisions
Drughi
I would call it necessary edge in Houdini and most software supporting polygons with holes. I guess, you need to operate over primitive borders and bridge edge is creating problems. So, you may convert polygon to separate polygons using Hole node with Un-bridge Holes enabled. To convert them back to single polygon with a hole, use the Hole node again with Un-bridge Holes disabled.
bridge_edge_problem.hipnc
