probiner Posted May 30, 2017 Share Posted May 30, 2017 Is there any point in using Attribute VOP set to Detail? I have been trying to use it because when I want to do calculations that are not mesh element dependent, in my mind, doing it in Detail will have better performance. But it seems I can't visualize them, so I wonder if I'm having some "wrong thinking" out of this. Example: I have a 0,1,0 vector on a Bind Export. It's visualized in both Primitive and Points, but not in Detail. You can see it color (green) but no vector or marker. I was expecting markers at the origin and vector rooted at the origin. But nothing. Let me know how Detail should be visualized. Thanks Quote Link to comment Share on other sites More sharing options...
eetu Posted May 30, 2017 Share Posted May 30, 2017 You can always copy the detail attribute to each point/prim for visualization.. Quote Link to comment Share on other sites More sharing options...
probiner Posted May 30, 2017 Author Share Posted May 30, 2017 (edited) Yeah but, then the data/vectors are rooted at the point/prim centroid... I neither wish to copy it to the elements or see data rooted on them. I just want to see that vector not per point. Imagine when I try to see an array of vectors. I'll see an array per point as well when just want to see the array? Feature request material? Edited May 30, 2017 by probiner Quote Link to comment Share on other sites More sharing options...
