visualize geometry inside of a dopnet
For a while I have been having a hard time visualizing the geometry from other sop nodes when I am inside of a dopnet inside a node.   The "Show all options" for viewing geometry only works if the dopnet is at the sop level. This also seems to be a similar issue if you want to visualize lighting on volumes.
i think the sopguide-dop could help?
another idea may be to convert you geo to a scalar (density) field and use the scalarfieldvisualization in DOPs.
only a guess though, not sure in your case.
