art3mis Posted June 2, 2017 Share Posted June 2, 2017 (edited) Hi Am I correct in assuming the File Cache is essentially identical to the File SOP but with more options? Is there any reason you couldn't always use the File SOP for caching? Also, why doesn't the File SOP by default recognize .sim files? Is it simply that .bgeo is always preferred, even for caching sims? Edited June 2, 2017 by art3mis Quote Link to comment Share on other sites More sharing options...
haggi Posted June 2, 2017 Share Posted June 2, 2017 Indeed, the fileCache sop is a expanded version of the file sop. You can dive into the fileCache sop where you can see that it uses the file sop as well. The big advantage of the fileCache sop is that it makes it easier to export sequences of geometry from the UI or in batch. Quote Link to comment Share on other sites More sharing options...
art3mis Posted June 2, 2017 Author Share Posted June 2, 2017 Fantastic, thanks! Quote Link to comment Share on other sites More sharing options...
