**VEX NOOB** create random float values
majinpu
Hi there !
I just started to do some little things in vex!
I can't understand  how to create a random integer attribute.
If i put down an attribute wrangle on some points and I type in:
f@number = rand(@numpt);
I can get some random float values.
But if i write in :
i@number = rand(@numpt);
I can just get 0 on all my points.
I think is very simple but I cannot sort it out! may be with a fit function?
thanks!
By default rand function creates a random number between 0 and 1 from a seed.
Multiply this value
i@rand_num = int(rand(@ptnum)*10);
or use fit function
i@rand_num = int(fit(rand(@ptnum), 0, 1, 0, 10));
And also in your example you used a @numpt as seed (which is return total number of points).
Hope it's help.
Edited by MagicRej
