Mantra Swizzle Coordinates (Direct X/Open GL Normal)
Hi all,
Not quite sure which coordinates by default Houdini Mantra uses for normal map, is it +X +Y -Z? I'm exporting Open GL normal maps from Substance Painter which were working like a charm in Maya, but seem not to be working correctly in Houdini?
Here's the comparison for other softwares.
Thanks!
Software Red Green Blue
3ds Max X+ Y- Z+
Blender X+ Y+ Z+
CryENGINE X+ Y- Z+
Maya X+ Y+ Z+
Modo X+ Y+ Z+
Source X+ Y- Z+
Toolbag X+ Y+ Z+
Unity X+ Y+ Z+
Unreal Engine X+ Y- Z+
The first thing to do is make sure that the Texture Color Space is set to Linear, for images where "flat" or unperturbed is defined as 0.5 float (or 127/128 in 8-bit channels).  I've had PNG's bite me that way before, where the file had a nonlinear gamma or something, and you just get "wrongness".
I'm fairly certain that Houdini uses +X +Y (on my Displacement Texture VOP node, both "Flip" checkboxes are off.)  This is, in terms of the appearance of the channels in Photoshop, "lit from the right" in X (red) and "lit from the top" in Y (green).  I can't speak to the Z blue channel, as its effects are really subtle, so if the blue channel were "wrong" in the textures I've been using, I wouldn't necessarily know by looking.  My current normal maps use 1.0 (255) for unperturbed, and range down to 128 for maximum perturbation, though mine are derived mine from the X and Y channel.  I would expect it to be +Z if for no other reason that it would be arbitrary to make that one -Z just to be contrary :)
I'm also assuming tangent space normals here.
Edited by jimmay
  • 2 weeks later...
yep, tangent space normals, should've mentioned that, although I think object space normals work with same system.
