art3mis Posted June 9, 2017 Share Posted June 9, 2017 (edited) Hi Was running Houdini 16.0.597 on my setup without issue: Ubuntu -Mate 16.04 Nvidia driver version 378.134 Decided I'd like to try and install the latest build 16.0.633(also tried 16.0.632) After installing, no errors but nothing launches when I double click! Next tried switching to the latest Nvidia driver 381.22 since 90% of any issues on Linux are related to Nvidia drivers:) Now I at least get a splash screen but then Houdini Indie crashes! The older 16.0.597 installer is no longer available so now am stuck as to what do... Anyone have any troubleshooting suggestions? Edited June 9, 2017 by art3mis Quote Link to comment Share on other sites More sharing options...
Guest tar Posted June 9, 2017 Share Posted June 9, 2017 the previous production build is there, https://www.sidefx.com/download/daily-builds/#category-gold but the main issue is that you encountered this same issue not too long iirc. Quote Link to comment Share on other sites More sharing options...
goldleaf Posted June 9, 2017 Share Posted June 9, 2017 If you run houdini from the Terminal, you might get more information. With Houdini installed in the standard location, open the Terminal and run: cd /opt/hfs16.0.633;source houdini_setup;cd --; houdinifx --foreground Hopefully, that'll give you more information when it crashes. Quote Link to comment Share on other sites More sharing options...
art3mis Posted June 9, 2017 Author Share Posted June 9, 2017 Hi Marty yes similar but not identical Previous (crash on launch) issue was due to an improper BIOS setting preventing nVidia driver from loading Current is incompatibility with most recent production build and latest nVidia driver. Finally have working again with QT4 version of Houdini 16.0.633 AND older version (the one that worked for me previously) nVidia driver 378.13. Now the problem is Redshift, which crashes Houdini on render:) The only solution it seems is to revert back to my older version 16.0.597 QT4 which I had to retrieve directly from sesi since it is no longer available to download. Next time will think twice before I upgrade Houdini.... Quote Link to comment Share on other sites More sharing options...
Guest tar Posted June 9, 2017 Share Posted June 9, 2017 Sounds weird as you never need to delete a previous Houdini to install a new one. Quote Link to comment Share on other sites More sharing options...
