Group by primvertexcount
konstantin magnus
I think the problem with that approach is you are only going to get one primitive as your result, which is what $NVTX > 4 produces. The group field does not iterate through the @primnums. If you place code in a wrangle running over primitives you can collect up all primitives that match the IF statement. Then just reference that group name in the polyextrude.
Edited by Atom
On 6/15/2017 at 11:05 PM, Atom said:
(image)
you can also just type:
@group_toExtrude = (primvertexcount(0, @primnum) < 4); //this is safer because the group will always be created (even if it is empty) that way you do not have issues using the groupPromote operation for instance
//or even simpler (run over prims):
@group_toExtrude = (@numvtx < 4);
