3d coordinates of the scene to 2d image coordinates
Hi im in houdini with a geometry that has a texture.
i render with a camera that has transform information such as translate, rotate, also the pixel aspect, focal lenght and aperture etc
 i render in 1920 x 1080
if i know the geometry points position in the 3d scene, how can i calculate in which coordenates in 2D 1920x1080 those points gonna finish at?
I'm not sure if Houdini has a quick and easy way to do this...?
Here's an article with a lot of detail about the process in a more general sense: https://www.scratchapixel.com/lessons/3d-basic-rendering/computing-pixel-coordinates-of-3d-point/mathematics-computing-2d-coordinates-of-3d-points
Don't know if that helps at all though.
This might not be entirely correct (it's late), but you can use the transform node in VOPs to convert from world space to camera space. Then setup a wrangle node like this:
vector res = chv('res'); // Screen resolution
float focal = radians(chf('Focal_length')); // Cameras focal length in radians
float angle = 2 * atan(0.5 / focal); // View angle
float frustum = 2 * -@P.z * tan(focal * 0.5); // Cameras frustum size depending on the distance
vector screen = set( (@P.x / frustum) + 0.5, (@P.y / frustum) + 0.5, 0 ); // Relative screen positions
v@screen_pixel = set(res * screen); // Absolute screen positions in pixels
screen_pixel.hipnc
Edited by konstantin magnus
  • 2 weeks later...
