divyanshfxartist Posted June 19, 2017 Share Posted June 19, 2017 (edited) Hello everyone, I am looking for a good processor for my new PC..I can afford Intel Xeon processor...so I have to stick with i7 or Amd Ryzen 7.. Intel i7-6800k Intel i7-7700k Rayzen 1700x I searched on net and find that Intel i7-7700k is not good in performance compare to i7-6800k and new Rayzen 1700x I already have AMD FX 8350 machine..with limited config.. AMD FX 8350 GTX 560TI CORSAIR VENGEANCE 16GB M5A97 R2.0 Antec gx505 Corsair TX750 watt This config is not giving any performance...AMD known for heating issue..random shutdown bcz of this..So I don't know trust to Rayzen or not..My new config which I am trying to build now is Processor & Motherboard : Need suggestions Ram : 32gb corsair vengeance PRO Graphic card : gtx 1070 Power supply : corsair TX750 Cooling : Corsair Hydro Series H100i v2 Cabinet : antec gx505 SSD : Samsung evo pro 250gb Edited June 20, 2017 by divyanshfxartist Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted June 19, 2017 Share Posted June 19, 2017 I'm assuming you mean the Core i7-7700K because there is no 1700K. The Ryzen 1700X will render faster and provide better bang for the buck in every regard. The only reason I'd go with Intel for a low budget workstation is if more than 64GB of memory is needed (Intel socket 2011-3 platform has eight instead of four memory slots). 1 Quote Link to comment Share on other sites More sharing options...
divyanshfxartist Posted June 20, 2017 Author Share Posted June 20, 2017 6 hours ago, lukeiamyourfather said: I'm assuming you mean the Core i7-7700K because there is no 1700K. The Ryzen 1700X will render faster and provide better bang for the buck in every regard. The only reason I'd go with Intel for a low budget workstation is if more than 64GB of memory is needed (Intel socket 2011-3 platform has eight instead of four memory slots). Yes I means i7-7700k..I am confused bcz I am getting mix review of i7-7700k..I all ready have AMD Fx 8350 machine with me..without Colling kit..its is not giving performance... It heats a lot..and shut down frequently..online I am getting info regarding AMD ryzan Is giving less heating and better multithreding output then Intel..which is surprising for me.. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted June 20, 2017 Share Posted June 20, 2017 A lot has changed coming from AMD since the FX days. That was five years ago which is a significant amount of time in the world of computers. Quote Link to comment Share on other sites More sharing options...
