evanrudefx Posted June 23, 2017 Share Posted June 23, 2017 Hey, I am trying to use a volume vop to create a ramp that controls the y density of my volume, so I can have it fade off. If you look at the volume vop in my scene, you can see that it kinda works. There seems to be a problem with the fall off. Any suggestions? clouds4.hiplc Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted June 23, 2017 Author Share Posted June 23, 2017 (edited) Any ideas? Edited January 31, 2018 by ejr32123 Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted January 31, 2018 Author Share Posted January 31, 2018 I know I posted this problem a while back, but it would nice to figure out : ( Quote Link to comment Share on other sites More sharing options...
mestela Posted February 1, 2018 Share Posted February 1, 2018 Might help: Quote Link to comment Share on other sites More sharing options...
coltonmil Posted February 1, 2018 Share Posted February 1, 2018 Hey ejr, Is the problem you're having the stepping you're seeing in the viewport? Falloff appears correctly in the render despite the stepping you're seeing in the viewport. Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted February 1, 2018 Author Share Posted February 1, 2018 2 hours ago, coltonmil said: Hey ejr, Is the problem you're having the stepping you're seeing in the viewport? Falloff appears correctly in the render despite the stepping you're seeing in the viewport. No, when you render it you can see the falloff isnot accurate. Quote Link to comment Share on other sites More sharing options...
coltonmil Posted February 1, 2018 Share Posted February 1, 2018 Which version are you using? It's working correctly in 16.0.742. 1 Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted February 1, 2018 Author Share Posted February 1, 2018 I am using 16.5 Quote Link to comment Share on other sites More sharing options...
wodH Posted February 14, 2018 Share Posted February 14, 2018 I guess you can do it in a volume wrangle 2 Quote Link to comment Share on other sites More sharing options...
