Facet SOP ignores group selection
Houdini7
Hi,
i wanted to use the Facet SOP on a certain selection of points. The node network looks like this:
The group parameters are as follows and select four points.
The Facet SOP parameter are as follows:
Every option I select in the Facet SOP (e.g. Make Planar) effects all points and not only the selected points. Has anyone an idea why ? Thanks in advance
Edited by Houdini7
Yeah, I suppose the algorithm used to calculate the normals runs through the whole geometry regardless
However, you can simply use the group in a wrangle just below to zero out the what you don't want
@vtrvtr: Thanks. Hmm okay, seems like a big oversight. So it is not possible (without custom expressions) to change cusp angle or make planar locally on a specific group.How do you handle such situations in houdini ?
Okay I have found the solution. The Group Type parameter has to be "Primitives":
Then the Facet SOP will take only the prims defined in the group. If you switch to "Points", then all points will be processed!
Edited by Houdini7
