houdini redshift error crash
houdini When you run it, you get an error and the houdini out. ㅠㅠ
help me~~~
houdini.env text
HOUDINI_DSO_ERROR = 2
PATH = "C:\ProgramData\Redshift\bin;$PATH"
HOUDINI_PATH = "C:\ProgramData\Redshift\Plugins\Houdini\16.0.557;&"
Edited by immeen
Have you checked if the redshift for Houdini version is exact the same number as your currently installed houdini version?
I've had this error before where I could create redshift nodes but when I clicked render it crashed. Problem was the version inconsistency.
The RS HDK plugin version number represents the HDK version it is compatible with, NOT the Houdini version.  What this means is that the RS plugin is binary compatible with even the Daily Builds of Houdini.  There's an important distinction here:  RS version number, RS HDK version number, and Houdini version number.
Not knowing what RS version or H version you're running, I would suspect that you need to update your environment file to point to the latest RS HDK plugin version of 633.
Edited by Daryl Dunlap
