Node reference
In Houdini 16 in the Network Pane go to View on the top stowbar under Dependency Links check on Show for All Nodes or Show for Selected Nodes.
In Pre-Houdini 16 in the Network Pane, press d and open the Network Editor Display Options go to the Dependency tab  and toggle on Show Local Dependency Links, or any of the top 5 in that list depending on what type of reference you want.
