logix1390 Posted July 11, 2017 Share Posted July 11, 2017 Hello everyone, I have some grids copied onto points. I want to rotate on each point. I created an attribute called "pivot" for each point and then did a few things in vops. It works, however, it is rotating all of the grids globally instead of rotating around its corresponding pivot point. I am also trying to rotate each grid randomly based on its class in vops , with no luck.. I will attach my file if anyone wants to take a look. Thank you. rotate_on_correct_pivot.hip Quote Link to comment Share on other sites More sharing options...
Sepu Posted July 11, 2017 Share Posted July 11, 2017 (edited) You had a few thing wrong in your set up, if you want apply @ to you points do it before you copy. Here is a working version. I added a wrangle version and a VOP rotate_on_correct_pivot_FIX.hip Edited July 11, 2017 by Sepu Quote Link to comment Share on other sites More sharing options...
logix1390 Posted July 11, 2017 Author Share Posted July 11, 2017 This is great Sepu. I was definitely over complicating things. Really appreciate the help ! Quote Link to comment Share on other sites More sharing options...
