jingaa Posted July 13, 2017 Share Posted July 13, 2017 Hello everybody , i was working on a project and stuck on some point...... Ok, i need to make something like this... I attach my file , is that possible to continue with that? or should i follow different way? particle_bullet_solver.hip 1 Quote Link to comment Share on other sites More sharing options...
violalyu Posted July 13, 2017 Share Posted July 13, 2017 Your setup is really close to what I saw on youtube from sweet and short 3d, and I tried this setup too. One of my colleague discovered that for similar stuff, using rigidbodysolver with pop source and rbdpackedobjects works basically the same and faster, for the collision it was more accurate in my case. But for the reference video I guess he used pop grain. 1 Quote Link to comment Share on other sites More sharing options...
kni8_2k Posted July 14, 2017 Share Posted July 14, 2017 this setup has a set number of points as the rest (this could be anything...) and the same number of points as the goal. Then just moves one to the other with two types of advection : force, or Velocity. you can make this setup pretty complex but this is the bare bones of it. particle_bullet_solver_kni82k.hip 2 Quote Link to comment Share on other sites More sharing options...
jingaa Posted July 14, 2017 Author Share Posted July 14, 2017 On 7/13/2017 at 6:01 PM, violalyu said: Your setup is really close to what I saw on youtube from sweet and short 3d, and I tried this setup too. One of my colleague discovered that for similar stuff, using rigidbodysolver with pop source and rbdpackedobjects works basically the same and faster, for the collision it was more accurate in my case. But for the reference video I guess he used pop grain. Expand I downloaded few hip file of Johnny Farmfileld about this thing and he is using grain generally. The thing is i need to make it with rbdpacked because of i am gonna use different types of objects on my character. Actually something like what Method Studio made u know dancing people with different type of things On 7/14/2017 at 12:13 AM, kni8_2k said: this setup has a set number of points as the rest (this could be anything...) and the same number of points as the goal. Then just moves one to the other with two types of advection : force, or Velocity. you can make this setup pretty complex but this is the bare bones of it. particle_bullet_solver_kni82k.hipFetching info... Expand Thank you so much for sharing the file with me , but when i merge an animation they dont follow them u know.... The thing what we wanna do is inspired from method studio, we wanna make random geomerties following the dancing person body u know what i am saying... 1 Quote Link to comment Share on other sites More sharing options...
jingaa Posted July 19, 2017 Author Share Posted July 19, 2017 Hello everybody.... I think i solved my problem and wanted to share here with you guys , if anybody wonder or wants to change little bit...... I decided to go with Grains and worked better i think. Gangnam Dance.rar 1 Quote Link to comment Share on other sites More sharing options...
