nigelgardiner Posted July 14, 2017 Share Posted July 14, 2017 Hi There I have Houdini 16 running on Ubuntu 16.04. Now I need to install a daily build. Could someone tell me the easiest way to go about this please? thanks Nigel. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted July 14, 2017 Share Posted July 14, 2017 Download the Linux installer, run it in a terminal with sudo, follow the prompts and use the defaults unless you otherwise have a reason to do so. You can install as many versions of Houdini on a machine as you want until you run out of hard drive space. Quote Link to comment Share on other sites More sharing options...
nigelgardiner Posted July 14, 2017 Author Share Posted July 14, 2017 Hi Lukeiamyourfather Excuse my ignorance.. I run Houdini from terminal, will running "Houdini" pick up the latest version or would I need to run "Houdini-version number"? thanks Nigel. Quote Link to comment Share on other sites More sharing options...
dedeks3000 Posted July 15, 2017 Share Posted July 15, 2017 cd to your different location ($HFS),source and run or create alias in your bashrc file(is that work ?) Quote Link to comment Share on other sites More sharing options...
nigelgardiner Posted July 15, 2017 Author Share Posted July 15, 2017 I think that makes sense, returning to linux/unix after twenty odd years so rusty as. Thanks. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted July 18, 2017 Share Posted July 18, 2017 Either launch Houdini with the menu item for the version you want (Gnome and other desktop environments feature this) or launch a specific version from the terminal. For example /opt/hfs16.0.633/bin/houdinifx for that specific version. There's a bash setup script in the root folder of each Houdini install which will crate temporary paths and such but you don't have to use it. Quote Link to comment Share on other sites More sharing options...
nigelgardiner Posted July 18, 2017 Author Share Posted July 18, 2017 At the moment I have to run source houdini_setup in /opt/hfs16.0.670 before running Houdini otherwise it defaults to Houdini16.0.633 so I guess I have something set up wrong somewhere.. thanks Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted July 19, 2017 Share Posted July 19, 2017 I don't think Houdini is in the path by default so it might've been added at some point. After you first login open a terminal and type "echo $PATH" and see what you get. Is there a Houdini directory in there? Quote Link to comment Share on other sites More sharing options...
nigelgardiner Posted July 22, 2017 Author Share Posted July 22, 2017 No, no Houdini directory. nigel@user-PC:~$ echo $PATH /home/nigel/bin:/home/nigel/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin thanks Nigel. Quote Link to comment Share on other sites More sharing options...
