noise rotation and move random on a master of setup in.obj
JIJIKV
hi everybody ! i have made a setup and all is linked to a null which is the master. is there someone who knows how to move rotate and scale 1 null master randomly with a noise(like mountain effect)??
i have tried something:
i have made a point thanks to scatter which move snapped by a mountain mesh under but i dont know how can i transfer the informations  of the point of move rotate to the null master which is the master of all my setup (in .obj not in geometry)
Edited by JIJIKV
You can drive the null transform using time based expressions.
noise(sin($FF*10),0,1)*22
By using $F, $FF or $T in an expression you can relay the current time into an expression to produce a unique output value for each frame.
