Save Fracture Pieces As Individual bgeo Files?
Hi All,
I have a basic cube that I have fractured. I have removed the outer shell using a loop. This leaves only the center pieces. I want to save each piece as it's own individual file. So I delete all but piece$F. This leaves one mesh in the scene to write to disk.
The above works, but I notice that on some frames I have a blank piece of geometry which result in zero length files on the disk. These blank pieces are the ones discarded by the loop as detected to being the outer shell. How can I avoid these blank pieces? And also how can I keep my frame number on the disk file from skewing when I skip a zero point count mesh?
ap_ts_fracture_inner_detail_ONLY_071817.hipnc
