Can't make "Font" function work
callandekeijzer
So I've been trying to follow this tutorial: at 13:24 he uses a stamp function and changes it to a 'stamps' (string) then particle fonts change to '0' and he continues with his tutorial. On my project however, 'stamps' doesn't do anything for me. Have I not set up the previous nodes correctly, or did i misuse functions? please help!
MatrixScreen.hipnc
That is pretty messed up. You have the Copy1 wired up backwards, points on right, what to copy on left. I don't think you can stamp a string using those old-style variable system. Just type your attribute directly in the attribute field and then you can stamp as if the attribute was a variable.
I added a wrangle which creates a random capital letter between A-Z.
ap_MatrixScreen.hipnc
Edited by Atom
