art3mis Posted July 22, 2017 Share Posted July 22, 2017 In my attempt at solving a pull focus issue I sourced the following script here on odforce. I then paste into a Python Script digital asset node. But how to get it to run/compile? Should it run automatically? #!/usr/bin/env hython _version = 0.11 ''' Inital Author: "SYmek" from od[force] community. Edited by: Farsheed Ashouri Thanks to everyone who have helped. For more information: http://forums.odforce.net/index.php?/topic/9725-creating-a-new-python-script-for-automating-camera-dof-setup-solved/ ''' import hou def computeFocus(): if hou.selectedNodes(): for node in hou.selectedNodes(): # print node.path() if node.type().name() == "cam": camera = node # else: target = node target = hou.node("/obj").createNode("null","DOF_Controler") theExp='vlength(vtorigin("%s", "%s"))' try: camera.parm("focus").setExpression(theExp % (camera.path(),target.path())) # cT = camera.worldTransform().extractTranslates() # tT = target.worldTransform().extractTranslates() # try: camera.parm("focus").set(cT.distanceTo(tT)) print "Done." except: print "Did you actually select any camera?" else: print "Please select a camera and a target." #if __name__ == "__main__": computeFocus() Quote Link to comment Share on other sites More sharing options...
