Set a value pre Primitive
Hi there.
I have an effect that triggers on a frame. This effect will happen on each primitive. I have an attribute on the primitive that says which frame the effect triggers.
My problem is that I dont know how to change that attribute for each Primitive. Right now I have something like this.
@effectTrigger = 10;
The effect triggers for all primitives on frame 10. What I would like to know how to do is something like this.
@effectTigger(PRIM number 0) = 10;
@effectTigger(PRIM number 1) = 13;
@effectTigger(PRIM number 2) = 23;
@effectTigger(PRIM number 3) = 48;
Cheers
Edited by revelationsr
You can always use an AttributeWrangle in Primitive mode to set specific values.
// Set default value first.
@effectTigger = 10;
// Override special cases.
if (@primnum == 1) {@effectTigger = 13;}
if (@primnum == 2) {@effectTigger = 23;}
if (@primnum == 3) {@effectTigger = 48;}
Edited by Atom
