Group by primitive size
Hi all, i'm trying to create a primitive group based on the size of geometry primitives.
In old version of Houdini, i recall i could use a Group sop, set it by Expression and use this: length($SIZEX,$SIZEY,$SIZEZ) > V ; where V is the size value to filter with.
Now in houdini 16 i have to use the GroupExpression sop, but it can read only vex, and i'm having trouble with it. I found in the help file that there still is a Length (vector) function, so i tried this: length (@size.x,@size.y,@size.z) > V, but it doesn't seems to work...
any advice on how to solve this?
ok maybe i solved it; instead of using the GroupExpression node i used an attributeWrangle with:
v@min = {0.0, 0.0, 0.0 };
v@max = {0.0, 0.0, 0.0 };
getbbox(@min,@max);
v@size = @max - @min;
f@tsize = @size.x + @size.y + @size.z;
and AFTER that, i used the groupExpression node with:
@tsize > X
where X is the value i want to filter with
I could create the group in the wrangle itself, but i found more confortable the group node cause it highlights whatever is inside the group.
It seems to work now, but if you have other ways it's always good to know ^^
