simple vector problem
Hello. I have two points. Each point has the same direction normal. I'd like to find out which of the two points is in front of the other, based on that direction normal. Is there a simple way to calculate this?
This is a 2D problem. Y is always 0 for both points, and the direction normal is always flat along the XZ plane.
you can compare angle between two vectors with dot product: the normal vector (v@N) and vector pointing from second point to the first one (v@difference = pt2 - pt1 , (pt1 and pt2 are positions of first and second point) ) and if angle is positive, then the second one is in front of, if negative, the second one is behind the first one.
Pseudo code could look like it
if (dot(v@N, v@difference) > 0) //second point is first
else //first point is first
  • Like 2
