"Look At" Vop
I'm very curious that "look at "vop, I did read the Houdini help file and try to wire the node in vop, but it not actually work.
So does anyone know how to use that node and the better to provide a hip file for learning?
Thanks alot.
  • 9 months later...
On 28/7/2017 at 8:50 AM, konstantin magnus said:
I think you have to define two vector parameters and feed them into "from" and "to". Then multiply the output with the position.
I would appreciate if somebody can give some example, information or h file about this "Look at" node. What are the common applications for it?
Thanks in advance.
