asxp3 Posted July 28, 2017 Share Posted July 28, 2017 I'm very curious that "look at "vop, I did read the Houdini help file and try to wire the node in vop, but it not actually work. So does anyone know how to use that node and the better to provide a hip file for learning? Thanks alot. Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted July 28, 2017 Share Posted July 28, 2017 I think you have to define two vector parameters and feed them into "from" and "to". Then multiply the output with the position. Quote Link to comment Share on other sites More sharing options...
Daverod Posted May 20, 2018 Share Posted May 20, 2018 On 28/7/2017 at 8:50 AM, konstantin magnus said: I think you have to define two vector parameters and feed them into "from" and "to". Then multiply the output with the position. I would appreciate if somebody can give some example, information or h file about this "Look at" node. What are the common applications for it? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
jon3de Posted May 22, 2018 Share Posted May 22, 2018 lookAtVop.hip 3 Quote Link to comment Share on other sites More sharing options...
