[redshift] dancing pixels
Hi
In the attached short clip notice on just the left side of the statue the rim lighting is creating a ‘dancing pixels’ or animated noise effect.
These are all the relevant settings. What should I try changing to eliminate these dancing pixels in the rim lighting?
Unified Sampling
Min 8
Max 256
AET 0.005
Sample Filtering
Type Gauss
Size 2
Max Subsample Intensity 4
Max Secondary Ray Intensity 4
Global Illumination
Primary Brute force
Secondary IPC
Num Bounces 3
Brute Force Rays 512
Irradiance Point Cloud
Frames to Blend 0
Screen Radius 8
Samples per Pixel 32
Filter Size 2
Retrace Threshold 3
Camera
Photographic Exposure enabled
Tone Mapping Allowed Overexposure 0
DOF enabled (Use Houdini camera focus/fstop)
Light(for rim lighting)
Samples 16
Normalize Intensity enabled
Intensity multiplier 70
Unit Type Image
Luminous Efficacy 0
Shadow Enabled
Transparency 0
White Marble (material)
Reflection
Weight 1
Roughness 0
Samples 16
BRDF GGX
Anisotropy 0
Rotation0
Fresnel Type Metalness
Reflectivity .04 .04 .04
Metalness 0
dancing_pixels.mp4Fetching info...
Edited by art3mis
